LED light bulbs
Kevoffthetee
On the road to nowhere
Has anyone upgraded to led bulbs at home. As the nights are getting darker, I'm wondering if its worth it in the main rooms.
Ikea charge £6 each for them so it would cost a few quid to change the living room, kitchen and stairs/ landing
Drago
I got them in some rooms. Seem to work well enough that no one notices.
marknotgeorge
Hol den Vorschlaghammer!
Derby.
I've relit my room with LED strips. I've fitted skirting board so the flat edge is 40cm below ceiling level, with the walls above painted white. It gives a good light - so much so I'm planning to fit a dimmer. The strips cost about £20 for 5m (10m was more than enough for three sides of my room), with the transformer about £30. If I were to do it again, I'd fit a wood strip between the skirting and the wall to hide the wiring better and possibly spread the light better.
by marknotgeorge, on Flickr
Rezillo
TwoSheds
Suffolk
Our new kitchen came with 8x50w halogen spots, which I replaced with these www.amazon.co.uk/Megaman-GU10-PAR16-Dimming-Light/dp/B009DCLLO0
400W to 48W at a stroke. I tried a few others first but they were nowhere near as bright as the originals. The Megaman ones have been fine and there looks to be a 7W version now.
I also replaced 8 x 20W under cupboard lights with 3W LEDs, so 160w went to 24W. The kitchen can now be bright for cooking and be dimmed to subdued to eat by. A year on and none of the LEDs have failed.
We have LEDs elsewhere, bought as and when they are on offer. There can be some shade variation - some of the warm whites, even from the same brand and model, can be more yellow than others.
marknotgeorge
Derby.
Sorry @marknotgeorge I was being a bit facetious!
It is the sort of stuff that they use in nightclubs and the like. I saw it in a hotel, where it was pointing downwards, and liked the effect. I have the stairs to the attic in my room, and it helps mitigate the shadow the staircase causes. I stayed away from the RGB coloured stuff!
slowmotion
Quite dreadful
lost somewhere
One thing to look out for is the life of the lamp. The manufacturers' figures can vary enormously from (typically)15,000 hours to 30,000 hours. Also, the efficiency varies a lot between lamps. The Which? best buy in a recent report cost an eye-watering £20 a pop.
slowmotion
Quite dreadful
lost somewhere
[QUOTE 3303981, member: 9609"]Make sure what colour you go for, 3500K and above is a very stark white light, 2500K is a much warmer colour for the home.[/QUOTE]
Thanks for the colour temperature information. I was going to look into that but you just saved me the trouble.
