lesson learned the hard way!
Beebo
Firm and Fruity
Hexleybeef
Can anyone beat this for a morning disaster?
Woke up, it was raining so I put on my new Night Vision Evo jacket for the first time, all seemed good.
Got a pucture after 25 mins. No problem I thought,
Plan A - I am fully prepared for these type of things I carry a spare tube. So I replaced the tube, put the wheel back on, went to pump the tyre up and found the valve was faulty.
Plan B - I will have to repair the tube in the rain, not ideal but I can do it. So being a fully prepared commuter I opened my trusty puncture repair kit, to find I had everything except a spare patch!! So now I have no spare tube, no repair patch, its raining and I'm still 6 miles from work.
Plan C - I will put the punctured tube back in and do the "pump and dash" technique to try and get me to work. but the tube deflated within 250m everytime I pumped it back up.
Plan D - I pushed my bike to work, I was cold, wet and over an hour late.
Lesson learned the hard way. I will never make that mistake again!!
akb
Sounds like an awful morning! Whats the plan for the return journey...?
ohnovino
Large Member
Liverpool
You could have tried cutting a square of rubber from the tube with the bust valve, and using that as a patch. Probably wouldn't make for a long term solution, but might have held long enough to get you to work.
mr_cellophane
Essex
I had a slow puncture Friday morning, forgot the spare tube and last patch. Can't find the reason for the hole and second one in the same tyre in a week. :angry:
twozeronine
Middlesex
I once cycled 10 miles on a flat, because I was too much of a noob back then, and used up all my patches trying to fix it (I kept applying them badly so that air was still leaking out). I also once cycled a few miles with BOTH tyres flat. A kind cyclist asked if I needed help, but I was near my destination by then. Incredibly stupid of me, and amazingly my rims survived.
I'm much more prepared & capable now though.
Beebo
Beebo
Firm and Fruity
Hexleybeef
If I had had a knife I would have done just that.
In my desperation I tried to glue half a business card on top the hole to try and stem the flow just a little but it clearly didnt work.
Twanger
It's rubber solution, not glue. Maybe that's why!
But what a good idea. I would never have thought of that. I have a swiss army knife in my repair kit...
cyberknight
I learnt the hard way to carry 2 tubes when it was so cold the rubber solution would not set in the middle of last winter when i have a double flat ...
