Yellow Fang
- Bury St Edmunds
The left crank arm of my Brompton seems to keep working off. I recently had to take the crank off to remove the pedal bearing and I wonder whether I back on tightly enough. Last night I used to mallet to bash the crank on as much as I could, then used my socket set to screw the bolt in tight. However, by this afternoon, it was wobbling again. I wonder whether I need to replace the left crank now, or even worse, the bottom bracket. I had a situation like this once before and I ended up glueing the crank on with some superstrong glue that you have to mix. Surprisingly that held up quite well, but that was on a cheap bike and I wouldn't want to do that with my Brompton.
