Mailard Screw On Freewheel Remover
BigTone0777
Darlington
Hi I am new to the forum and just getting back into cycling................so much has changed in the last 10 years or so!!!!!
I am looking for a removal tool to fit a Mailard screw on freewheel. This is much bigger than the atom one, 30mm in diameter I believe. Does anyone have any idea where I can get my hands on one or do any of you have one for sale?
Looking forward to your replies!
Tony
C
chillyuk
SJS Cycles list one. Look Here
I take it that your Mailard with one "l" is a typo. Maillard with two "l's" comes up with several results on a search.
BigTone0777
BigTone0777
Darlington
It wasn't even a typo it was just blatant bad spelling!
Unfortunatelly that's not the one, the one I have has approx 20 splines. I'll try to post a pic of the freewheel when I get home as I'm at work at the moment. Everyone around my area scratches their head and say's I haven't seen on of those for about 20 years lol.
gbb
Peterborough
Shame cos ive got one. Its always worth trying a LBS, i got mine from off the shelf...mind it'd been there for donkeys years i suspect.
Where are you BigTone ?
gbb
Peterborough
Tha Maillard one ive got isnt like the one in your link Chilly...mines got loads of splines on it.
Ironic, loads of old cheap Raleigh 5 speed racers have these maillard freewheels on them...i 've had two do'er uppers in the last 6 months with them on.
Zoiders
It might be a Helicomatic freewheel.
lots of splines on the outside edge of a thin lockring, approx 30mm dia., with the freewheel body just sliding off helical splines on the hub.
http://www.sheldonbrown.com/velos.html
http://www.yellowjer...org/helico.html
This.
A mole grip will do at a push if you can't track down the original lockring tool.
BigTone0777
BigTone0777
Darlington
BigTone0777
BigTone0777
Darlington
Let's see if this works!
Bokonon
I once had a freewheel with a non-standard splined fitting that I couldn't source a removal tool for. In the end I used a length of square steel machined to fit snuggly between the splines in place of the proper tool.
