Mickle Method of chain cleaning - assistance
david1701
Bude, Cornwall
I started out cleaning with spray degreasers till everything shined then oiling and wondering why it was filthy within a few days and crappy. Evenetually got links so stiff the chain would shift on the big ring of its own accord to match the cassette.
Then I moved to the mickle method of wipe till cleanish, oil, wipe off oil. This worked wonders for a few days then it got stiff, fine still crappy so I did it again. Happened a few times and I seem to need to clean the chain every few days to keep it smoooth.
Am I doing it wrong or is the chain just a bit fc-uk'd from previous abuse?
rockyraccoon
What lube do you use (on your bike! :smile: )
It could be the type of oil you are using.
david1701
Bude, Cornwall
erm chain juice wet
@ Mickle should I baby it through the winter then go new chain new cassette in the spring? or just chop a new one in now?
Scilly Suffolk
If your chain needs replacing, I'd do it now; otherwise you risk having to change your chain, cassette and possibly chainset.
david1701
Bude, Cornwall
sweet so they are interchangeable :biggrin:
