stuee147
- north ayrshire
well not before time iv started on MK3. iv been taking it slow and this time like on my first build im not working to any plans.
i spent hours looking at plans and designs and lots of youtube and atomic zombie posts trying to find something that appealed, but i could never find just what i was looking for, so the idea to just see how it turns out came about.
i started off with the rear wheel and decided i wanted a 26inch rear wheel mainly for the ease of getting a ready built hub motor E-kit. i found some old rear triangles and started to play about with them i decided not to go for rear suspension this time, i have found that its a bit smother ride on MK2 with the rear suspension but the setup was a lot more complicated espeshely with the drive system and gears. iv also gone back to a similar frame design as MK1 with the pedals being slightly raised above the seat. i find MK2 very comfy but MK1 with the raised pedals i found a little more comfy over distance. and i found i seemed to be able to get more power into the pedals with them raised slightly.
i have also decided to play about with the drive system iv incorporated 2 drive systems onto MK3. the first is a fixed single speed system that sits on the left side of the frame from the front BB running to a second BB in the middle. this takes a direct drive from the pedals at the front to a BB in the middle just infront of the rear wheel. then the drive is transferred threw the middle BB to a triple on the right hand side which has a chain going to the rear wheel just like on a DF bike. the reasoning behind this designation is firstly with the fixed gear at the front it makes it easier to hide the chain away so i dont end up with the inside of my leg looking like an oil rag lol but also with the fixed gearing at the front i dont have as many problems with the chain line going under the seat and so on which has been a bit of a issue on other builds. im also considering covering the front chain either boxing it in or some form of tubing.
im also making MK3 a folding trike, its not designed to fold up and fit into the boot of a car or anything its more just folding the front wheels in to make the trike narrower so it will fit in and out threw standard doorways. iv played about with how i was going to do it and iv made it so all i need do is undo one bolt and then a QR balljoint on the track rod and the whole thing will fold so it should be a relitvely quick process.
iv not fully decided on the front wheels yet, i have been considering 18inch and 24inch wheels but i think ill probably stick with a set of 20inch on the front but as yet iv not made a final deasition . i would love to go with disk brakes on the front but as im not able to build the wheels myself (lack of confidence) and money is always an issue so getting them built for me isnt really an option so iv been considering a pair of 20inch wheels with disk brakes on but iv only been able to find them with a 10mm axle which wont be strong enough to be supported on just one side so i would have to make up a set of forks for the front wheels. thats no real problem its more the look of it i think it looks better with the wheels supported on just the one side like i have on MK2. but if i go with the 14mm axles like i have on MK2 i cant find them with the disk brakes. and i do find the brakes i have on MK2 (rim brakes) just dont have the stopping power i would like. im thinking along the lines of making a frame up to take the wheels with disk brakes, and making it so the frame work covers the top half of the wheels (sort of box them in ) this way im less likely to catch my hand or anything else in the wheel when im riding it but also it will help stop any dirt, stones or water getting sprayed up onto my hands and me. i think it will also make it look quite good, its something im going to need to make a desition about it very soon now, so any ideas or thoughts are as always more than welcome.
anyway here are a couple of pics of what iv done so far its not much but it is getting there lol.
and here is the front boom with the folding mechenisum tack welded together
iv also been spending on bits and bobs. iv got 3 x 12volt 14AH battery's that i have a plan to make a electrics box under the seat to take the 3 x 12V battery's for the E-kit and a 6V battery for the lights and a usb phone charger. the battery's are more powerful than the ones i have on MK2 so should give me a bit more distance (around 25 to 30 miles on a full charge) the 6V system will be charged via a dynamo on the rear wheel the same as on MK2 which works really well. i will have front and rear lights fitted and indicators and brake lights like i have on MK2. the main difference im doing to the 6V system on MK3 is im going to have a 5way waterproof connector at the rear so when i put the trailer on the back (as i do a lot with MK2 ) i can disconect the rear lights on the trike and connect up a set on the trailer by simply swapping the leads over. this is something iv wanted to do on MK2 for a while now but not got round to it. i use the trailer about once or twice a week on average so its something i need.
iv also got a new rear light cluster that i think is great and will look so cool on MK3
the large skull in the middle has both rear LED and brake LED lights in and the 2 smaller skulls are the indicators with orange LEDs in the eyes and nose and it looks so good when all lit up lol. i have found a matching skull for the front with whight LEDs for the eyes and mouth but its almost £80 so i might just go with a normal 6v light on the front but i am looking at getting the skull indicators for the front .
here are the mirrors im getting the red will match the frame when its all painted and yes black and red are my colours again lol
iv still got a fair amount to do to get MK3 running but im not in any real hurry as i have and use MK2 alot but its getting there. iv still got things to decide on such as the front wheels and braking system and even how im going to do the seat iv not decided weather to go for a fixed sold seat of one more like i have on MK2.
im also undecided on gears so far. on MK2 i have a shimarno system with a triple on the front and a 7 speed rear with mega drive 1st gear. i do quite like the gearing i have but since i have got the E-kit iv found i really dont need the mega range first gear in fact i dont think iv even put it in first gear since i converted it. also i find with the gearing i have on MK2 my top speed is about 18 to 20mph on the flats which is very good but i do find my legs are flying round a million miles an hour to get and maintain that speed so im thinking of going for a higher gearing ratio so in theory i will find it easier to get to and maintain a good top speed.
im hoping that when i finish MK3 i will have a lightish trike that will be good for nipping to the shops or going for a long days ride. like iv said i will be using a trailer quite a bit and im looking at fitting panniers to the back probably motorcycle ones like i have on MK2 as i like the fact i can lock them up and not have to worry about them getting stolen.
anyway iv been trying to sort my workshop out the past couple of days as soon as that's done i can get back to building MK3 as long as iv decided on the front wheels lol. as always any ideas or suggestions are always warmly welcomed
stuee
stuee
