Moussaka
Salford
Need to cheer someone up so I thought I'd make his favourite dish; Moussaka.
Now, I've never made it before & only eaten it once (years ago).
This recipe appeals because it looks easy enough and I like Rick Stein
  1. What do I serve it with?
  2. Are aubergines (loathsome, horrible things that they are) even in season? Will I be able to get some?
MossCommuter
Salford
PS: what about potato slices instead of aubergine?
col
This is our fave at a local restaraunt too. The aubergines are a personal taste thing, i dont mind them but my wife hates them. Serve with chips and white sauced cabbage, or even a salad, my mouths watering thinking about it :thumbsup:
swee'pea99
I'd go with the recipe as it stands - I reckon you might surprise yourself. Aubergine can be absolutely fantastic cooked like that, in 5mm slices - in fact, you've reminded me of an 'aubergine lasagna' (basically just like a lasagna, but with fried/floured/egged thin slices of aubergine substituting for pasta) I used to make, much like that, before the munchkins came along - it was fantastic. Actually, where is that recipe....?
the_mikey
I love Moussaka, and aubergines, that recipe is a bit heavy on the aubergines, I use one or two aubergines depending on size, one or two cans of chopped tomatoes, but also I add a fresh sliced beef tomato, potatoes (sliced and parboiled) , oregano, Lamb mince and some pasata added to the cooked mince. Also before it goes in the oven I top it off with either grated italian cheese, or failing that, mature cheddar will do. It tastes AMAZING when it comes out of the oven (at 180 degrees for an hour).
asterix
Comrade Member
Limoges or York
Just remember that the emphasis is on the first syllable* and you'll be fine.
*was told this by a Greek. But hey, what do they know?
MossCommuter
Salford
thanks all
we're going for pizza :blush:
I promised to do the moussaka some other time; I'll use the Stein recipe but halve the amount of aubergine I think. I'll try to remember to let you know the result.
brockers
Sounds like a meat-infused version of 'Melanzane alla Parmigiano' - a classic Italian dish. You can substitute any old formaggio for the parmesan too.
guitarpete247
Just about surviving
Leicestershire
I use aubergines but I don't fry them. Instead, after salting, rinsing, patting dry then dusting with seasoned flour, I brush them lightly with olive oil then grill them for a couple of mins each side. I would use 3 for that amount of meat but usually make mine to serve 4 not 6 so use about 500g of lamb and drain off the fat once I've browned it (using less olive oil this keeps the fat percentage down)
