N+1
Paulus
Barnet,
If you need a folder, £13.50 isn't bad at all. The saddle looks a bit iffy though. Well done.
Speicher
Vice Admiral
It's make a great front-wheel drive 'bent...
What??????
On that same site is a bike bus, for nine people, with six wheels! :biggrin:
Night Train
Night Train
Maker of Things
I've got it home.
The little plastic bottle dynamo doesn't click over to touch the tyre.
It has a Shimano hub gear.
With a twist grip shifter.
Both wheels need truing and some of the spokes are very loose. The chome work is covered in rust spotting and it needs a good clean up and a bit of lub on the moving parts.
I have changed the saddle for one off an old MTB and the pedals are off for changing for folding ones.
It folds ok bit the QR levers are a bit fiddly to work. I will need to look for replacement tyres and maybe tubes as they have different valves and the rear one is twisted inside the tyre. The tyres are also badly cracked on the sidewalls. The brakes work ok despite the rusty rims but I'm not sure I would trust them loaded and at speed.
It'll do for now.
