Cush
- North Cumbria but still a Geordie
Just witnessed what was nearly a punch up between two cyclists and a motorist and it brought up one or two interesting points. The motorist turned in to a very narrow road that is one way only, it goes steeply down hill and leads to an old railway line used as a NCR, on one side is a very narrow pavement. The turning is off a dual carriageway, it is very tight and crosses a pavement shared by pedestrians and cyclists. I often use it as a motorist and know how awkward the turning is, you have to slow down almost to a stop because of the pedestrian / cyclist element but at the same time you have to watch your back for the traffic coming behind you on what is a very busy road.
I came on it today as two cyclists in full urban camouflage and .panniers came out of it two abreast and were nearly in to the motorist turning into it. The cyclists immediately started to give the driver lip in a very aggressive manner. I pointed out that they were coming out of a one way road the wrong way and one of them pointed to a National Cycle Route way marker showing a right and left turning. The marker is on the post that carries a No Entry sign. I did not get involved any further but carried on down the road to join the cycle route. The motorist over took me as I was turning on to what I know as the cycle route and his fist came out of the window, don’t know if it was friendly wave or a Damm all cyclists one. I will make a point of either cycling or walking past that area in the next few days to check out that sign and will be carrying a camera. My sympathies here was with both parties who until I do a full check were I believe caught out by bit of bad road planning.
