rh100
I have a new 7 speed cassette (Shimano HG30) to go on a new back wheel, complete with the spacer as it's an 8 speed hub. The question is, there is a light coating of grease already on the hub, does it need anthing else? I haven't changed the chain yet but was going to oil and clean the chain again to get some onto the cassette - will this be sufficient? The smallest two cogs of the cassette are loose - I presume just pushing these on in the right order is corect - no other spacers required? The seven speed spacer I will place at the inside of the cassette, not the outside - is this right?
Also - when fitting the cassette -how tight to do up the lock ring? just pinch tight or give it some welly?
Also - the new wheels came with shimano QR skewers, would these be better than my current silver transx (more of a square handle type) ones? I think both sets are only cheap but the transx ones look a bit better IMO and the shimano ones have a circlip holding the lever on - which has failed on a (cheaper) set in the past so not overly keen.
Going to be a busy weekend - have a full set of brake and gear cables to change aswell - hope it rides a bit better after this lot.
