Armegatron
Hi all,
I have been using my bike for commuting in this icey snowy weather and havnt really done much in the way of servicing, apart from chain and frame cleaning. Ive had the bike since September and have so far done 650 miles.
I removed the front wheel from the bike yesterday and as I loosened the QR the wheel rotated. I thought this was slightly odd but didn't think much at the time. Anyway, after sorting everything else out I moved onto the front wheel and noticed that the axle (not sure on technical names yet so bear with me) was notchy in its movement and not smooth like the rear one.
I fear that some road salt may have entered the bearings, or the grease may be thinned due to natural wear and tear.
I was able to remove the cones and have a quick look, but decided to carry on tonight after work. So, putting it back together I noticed that if I barely tighted the cone up against the bearings it was fairly smooth.
So, my questions are (and thanks for "bearing" with me ):
Mike
- What do I need to do to clean the bearings up? (remove balls, GT85 / White Spirit, re-grease with lithium)
- Do I need to just tighten the cone to hand tight or is there some mechanism internally that prevents enovertighting (like a flange)?
Mike
