I've got an Autel Maxi AP200 and it does everything you might need for about £50. It doesn't do anything fancy like re-programme things but it will read and clear fault codes. It works fine on our Discovery 3 and VW Lupo.I realise these go to thousands of £££ , however any recommendations for the home mechanic ? Engine management light onnsons car , likely hood it’s a an oxygen sensor , google suggest it’s common . However be good to get the code read.
Had a problem with O2 sensor on our 2009 Beetle last week, garage said lots of similar problems recently and suggested a possible link with the new E10 fuel.I realise these go to thousands of £££ , however any recommendations for the home mechanic ? Engine management light onnsons car , likely hood it’s a an oxygen sensor , google suggest it’s common . However be good to get the code read.
I have the same issue again suggested related to E10 I have switched to E5 but need to reset the warning light again to see if it stays clearHad a problem with O2 sensor on our 2009 Beetle last week, garage said lots of similar problems recently and suggested a possible link with the new E10 fuel.
It might reset once you have run the car a few hours. If its a fuel trim issue, the car will relearn with E5 fuel. A fault will most likely keep the check engine light litI have the same issue again suggested related to E10 I have switched to E5 but need to reset the warning light again to see if it stays clear
