Oh dear. I've lost my memory.
slowmotion
Quite dreadful
lost somewhere
I wonder if you can help me get it back.
I have a Compaq desktop running Windows XP. I'm reasonably sure it hasn't got any totally ghastly infections...it's just running out of space on the hard drive.
The hard drive comprises..
1) Compaq (C) 20GB total with less than 1% still free to use
2) HP Recovery (D) 10 GB with 50% still free to use
3) Local disk (E) 120GB with 99% still free to use
There are no external memory devices in use usually.
Nearly all the operating system, my programs and files, and all the internet stuff and emails live on Compaq (C) but the memory on that drive is so low that I'm grinding to a halt. Drive (D) is handy when I have to re-install the OS and drivers so I don't want to touch it. I would like to use some of the memory on drive (E) to bring drive(C) back to life. Can I do that? If so, how?
Thank you very much.
Kies
Go to control panel > performance and change the location of the page file to live on E:
Delete the page file from c:
Next go through all your data, and move as much as possible to E:\documents
Find your C:\temp folder and delete everything
Reboot and see the difference
Edit: you can configure your email so that the *.pst files can live on E: , this will save a lot of space on C:
slowmotion
slowmotion
Quite dreadful
lost somewhere
Thank you. Being a bit of an idiot, I think it might be best to back up my stuff before I attempt Mission Impossible. Lacking a memory stick at present, I will hold off for the present and content myself with reading your links.
Kies
Anything moved to the E: drive would be safe even if you totally screwed up C: which is where windows lives, but always a good idea to do a backup of your data.
Shut Up Legs
Down Under Member
I dimly remember reading that moving my program files from (C) was not a good idea. Is that the case?
Yes, don't do that. You can uninstall programs from C: drive and reinstall them on another drive, but even with that, you'll still have the problem of copying your program's settings over to the new installation.
