joolsybools
- Scotland
Hi, I'm hoping there are some Brommy brake cable and lever gurus out there please!
I have a very old (10 years) Brompton, it's one of the little red ones that came with a 3 speed hub and no mudguards etc, what I think was classed as an M3C which is equivalent to a modern M3E. I understand that it has a short wheel base as the long wheel base didn't go into production until much later.
The front brake cable snapped a few months ago and I have only just got around to sorting it out so I have ordered and now received new brake cables for both front and back as I thought the back could probably do with renewing too. Now I thought I was buying the correct parts as in QBRCABFA-M/P for the front and QBRCABRA-02 for the rear BUT (there's always a but isn't there!) when I looked at the packet it shows that they are not compatible with my (very old) brake levers. Now you wouldn't think this is a problem...just get some new brake levers! There is a bit of play anyway in the front (right) one which I had forgotten about, so they could do with an upgrade.
I think my current brake levers might be classed as 10 degree ones, but am not 100% certain. Now from the packet it looks like I could replace my R (front) lever with a
The rear or L lever/brake situation looks to be a bit more of a problem as the picture shows the cable is only compatible with a slightly different Brompton branded 10 degree lever which you do not seem to be available to buy new anymore. The only thing I can think of would be to buy a 30 degree lever and a corresponding cable for a short wheel base but this cable does not exist (that I can find anyway!). So basically I am at a bit of a loss as to what to do.
Am I being thick? All constructive suggestions welcome! Thanks
QBRLEV30RH
, which is a 30 degree lever - if anyone thinks otherwise let me know!The rear or L lever/brake situation looks to be a bit more of a problem as the picture shows the cable is only compatible with a slightly different Brompton branded 10 degree lever which you do not seem to be available to buy new anymore. The only thing I can think of would be to buy a 30 degree lever and a corresponding cable for a short wheel base but this cable does not exist (that I can find anyway!). So basically I am at a bit of a loss as to what to do.
