Paintwork issues
brucers
Scunthorpe
I have an alu frame bike with bubbling paintwork around the screw holes where the drinks holder fits. There is also flaking paint around the ends of the carbon forks.
Whats hint n tips do people have regarding preventing them getting worse. The forks I wonder if painting or clear varnishing over them will reseal the paintwork effectively.....also are there considerations with carbon and what liquids can be used without damaging the carbon itself? The bike is about 6 years old.
Loch side.
You can't prevent it from getting worse but it will self-arrest after creating a nice eyesore.
The paint at those points bubble because of galvanic corrosion between the carbon and aluminium/steel parts glued and crimped in. The glue does not create a perfect insulator and a small electric current runs between the two parts, oxidising the aluminium which in turn lifts the paint. Putting clear varnish over it will do nothing.
Welcome to the world here the salesman and brochures and magazine (wannabe) writers don't tell you about carbon's dirty little hidden secrets.
youngoldbloke
Is it safe to use forks where this is visible?
B
brucers
Scunthorpe
Thanks for that. Far too technical for my laymans mind but I get the gist!
pclay
Rugby
I had bubbling paint that eventuallly start to peel off on my 4 year old Cannondale synapse. I used a bit of sandpaper to smooth out the paint, and then painted on with modelling enamel paint of the same colour.
Any recourse under warranty if you were the first owner and the frame has a lifetime warranty, a la Specialized fur example?
B
brucers
Scunthorpe
I take it that it's stopped the bubbling from spreading?
Loch side.
No, it can't stop the bubbling from spreading, it only removes current corrosion and starts afresh. The problem is with the use of two different metallic materials in close proximity. Carbon fibre composites in this case also acts like a metallic anode or cathode.
Globalti
My first carbon bike had a few places where the very thick glossy brittle red paint had chipped so I took a tiny flake of the paint stuck to some Sellotape and went to Boots to buy some nail varnish. The sweet young shop assistant did a good job of helping me choose the nail varnish while making it clear she didn't believe my story; in fact at one point she actually said: "How about this one? This will look really nice on y....."
As I left I could imagine her heaving a sigh of happiness and thinking: "Thank goodness I did my customer inclusivity training!"
