What wheelset have you got, been looking at the aeroage with the Fix-g hub, isn't nearly 2kg heavy?Lovin' mine.
What wheelset have you got, been looking at the aeroage with the Fix-g hub, isn't nearly 2kg heavy?![]()
I've got the stock wheels on it. I wouldn't get these again as the braking on them is poor (I'm running koolstop pads).
The only downsides i've heard about the aerorage are the deep rims, but the stock rims from pearson are deeper.
Deep? They are 25mm thats not deep :S
Why is that a disadvantage? I ride 30mm rims on my fixed and there is nothing to complain about.
ok not deep deep but you need to use long valve tubes on them. The stock ones are 30mm deep.
They are affected by crosswinds. If you don't notice it then you are lucky, if you do notice it then the first few times a gust comes along and you move sideways quite a bit if you aren't aware.
plus I've heard some negative things about the Halo Aeroage wheels that are an option.
