Puncture protection
Dogtrousers
Kilometre nibbler
Today a dreadful scraping sound from my back wheel caused me to pull up. I guessed that a stone had jammed between the wheel and the mudguard but I found this:
standalone
But no puncture. The Durano Plus tyre protection had done its stuff! I needed pliers to remove the nail.
standalone
You can see how long it is and deeply embedded it was.
A number of things had combined to save the inner tube: The tyre's puncture protection, the fact that the nail (or whatever it is) was flat ended, and not sharp, and the fact that the tyres were pumped up very hard.
I was most impressed with the fact that no puncture resulted. All the same, I'll have a closer look at how much damage was done to the tyre.
That said, the same tyre was punctured a couple of weeks ago by a teeny tiny shard of glass.
Nice. The wonders of modern technology!
raleighnut
:eek: The angle probably helped it not go through as well, I seem to remember that the cut section tyre (Schwalbe) display I saw had a carcass under the protection not outside it so if the tyre doesn't go out of shape and the inside is still solid/undamaged I'd carry on riding it.................On the back though. :biggrin:
BTW that's a pallet nail, driven in by an air gun and the lack of a point is to prevent splitting crap timber.
Shut Up Legs
Down Under Member
I had something similar go straight through a Marathon Plus tyre a while back. Oddly enough, it entered the tyre radially and so a puncture was inevitable. You had a bit of luck there, @Dogtrousers .
Beebo
Firm and Fruity
Hexleybeef
The problem is you will now get bits of grit in the hole left by the nail.
I had a similar experience on my bike, i had a clicking noise front the front wheel.
I stopped and found a nail in the side wall, pulled it out, expecting an instant deflation, but the tyre stayed inflated.
