luplowe said:Ok thanks all ill stick some in. (should of bought a Kia)
Regards..........
Damned right, they are easier to spell
A m/cycle engine from a bike like a Yamaha R1 will consume 1 litre of oil every 1000 miles and this is considered to be normal (they do rev very high though, and have thinner rings for less friction on the pistons).
Diesel engines need their oil changing more regularly because the pressure is so high in the combustion chamber, that it forces diesel fuel past the oil scavege rings into the sump. This offsets the proper engine oil and gives the illusion that the level is OK, but as diesel has no real lubricating properties, it helps to wear out the engine much faster - hence a petrol car has a oil change every 10-12,000 miles and a diesel car every 6,000 miles.
