Hi All,
Sorry maybe a stupid question here but im struggling a little to grasp the concept.
I have mech disks on my bike and im unsure when to tighten the cable as opposed to moving the pads closer to the rotor ?.
I mean if the lever is slightly to loose you can fix this by moving the pads closer to the rotor if possible, or by tightnening the brake cable up, I just want to know what I should be doing as opposed with tinkering with the lot.
I understand that you should not compensate pad wear with tightenening the cable but apart from this when do you do either of the above.
How do you know if you have cable stretch for instance ?.
Many Thanks
Many Thanks
