Question for the glasses wearers amongst us
tyred
Ireland
How do you clean yours?
I picked my new pair up yesterday, there was a tiny change in the prescription but the real issue was the amount of scratches on my old pair. It was like looking through a pane of frosted glass.
My glasses always seem to end up being all scratches. The previous pair I only ever cleaned with the cloths I get from the opticians yet they still ended up all scratched. I realise I do things like lie under old cars wire brushing off rust that is probably not in the design spec but am always careful to try and blow any grit of them before wiping them.
I have seen it suggested that it's better to clean them under the tap with a little Fairy liquid rather than clean them with a cloth. Does anyone do this?
snorri
If you are a wet shaver, a quick dicht with your soapy shaving brush in the morning does the trick!
Otherwise, mine get the Fairy treatment.
Chromatic
Gloucestershire
I clean them under a tap with a little soap every now and then. Usually I just breath on them and wipe with an item of clothing that I'm wearing at the time. Do you have anti-scratch lenses? If you're under cars and getting shoot all over them it would be better to rinse them off with soap and water before polishing the lenses, getting them wet won't harm them
tadpole
St George
I never use the cloth supplied by the opticians, well never more than once.
I wear more than one pair of glasses, reading glasses, mid distance glasses, as well as my everyday glasses, and for all my glasses I use "screen and spectacle wipes" (from staples). and a soft paper tissue. I also pay for the anti scratch coating on the glasses when I buy new ones. My glasses tend to last two years before the scratches on the lenses become a problem. As for washing-up liquid, my company issued safety glasses carried a warning not to use it as it softened the anti scratch coating making it more prone to marking.
tyred
tyred
Ireland
I don't have an anti-scratch coating (didn't know you could) but I always specify a an anti-glare coating which I find makes driving at night much easier. It is always this coating which seems to scratch off over time.
Chromatic
Gloucestershire
If you wear them in a dirty environment, like it seems you do, it would be worth your while asking about anti scratch for your next pair. I don't suppose its a totally bullet proof thing and you should still take precaution to clean them sympathetically, but it certainly would be worth while.
PK99
SW19
i switched from plastic to glass lenses! much easier to clean without scratching.
tyred
tyred
Ireland
Is there much of a price difference?
Cubist
Still wavin'
Ovver 'thill
The coating isn't cheap, but I wear varifocals which cost £300 or so. They have lasted 3 years so far., although I don't do the covering them in rust thing. I use the disposable eyewear wipes from Aldi.
