Yes, my mum used to breed rabbits so i know a bit.
1. consider getting one from the rspca. They have hundreds, mostly from people who bought them from Pets at Home not realising how much care they need.
2. Clean out their poo corner once a day. use newspaper in the corner covered with wood shavings (not sawdust as it's irratating to their eyes and nose). the woodshavings will help soak up the wee. just roll the feaces/wee up in the newspaper when you want to change it.
3. fresh food and water each day (goes without saying)... dry rabbit mix every day. too much fresh veg can give them the runs but they should have some, so maybe once or twice a week (carrots are good)
4. Make sure their bottom is clean, especially in the summer months as they can get fly strike. this is when flies lay eggs in the faeces stuck to the fur around their bum. the eggs hatch and the maggots bury into their flesh. not very nice as you can imagine.
5. they may need vaccinating. (if you get it from rspca they will probably have done that already)
6. lots of cuddles as they are prey animals and will become fearful and bitey if you don't handle them.
7. talking of teeth, and claws, they may need clipping if they get too long. rabbits are natural diggers and knawers and without a natural habitat they may grow long. rabbits teeth should grow straight and together. when they get long, they are like fingers nails, they will grow apart and twist to the sides, eventually growing into their own mouth, lips and gums. make sure they have some wood to chew on (you can buy it from the pet shop) and just keep an eye on their teeth and claws. if teeth start getting long, go to the vets. if the claws get long, if they are white and clear and you can see the blood vessel, you can do it yourself (buy clippers from the pet shop), just clip before the blood vessel. if claws are black and not transparent and you can't see the blood vessel, might be best to get the vet to do it.
8. if you get a run, make sure it has a shaded area.
9. hutch should be kept in the shade, with a rain cover. Blanket over it at night in the winter, or move the hutch into a garage/shed.
10. check water twice a day in the winter to make sure it's not frozen.
that's it really.
