numbnuts said:April fools day was yesterday
User76 said:he reckoned it was because the mud had got into the gaps between the strands of the carbon
RedBike said:Unfortunately the rain DOES effect some carbon bikes - Honestly!
The carbon doesn't normally get damaged directly, it gets damaged by the metal parts that are bonded / fastened to it.
Cheaper carbon frames often have aluminium lugs and even the more expensive frames often use aluminium seatposts, bottom brackets and dropouts.
Q: On your web site you have indicated that aluminum and carbon fibre react so as to cause cathodic corrosion. Is this also the case with steel or cromoly steel and carbon fibre?
A: Yes, it is a problem with steels as well as with aluminum alloys. The easy solution is to prevent contact. One way to do this is to include a single light ply of fiberglass in the layup as an electrical insulator between the metal and carbon. Trek did this with their bonded aluminum lug carbon tube bikes. Specialized did too, and Kestrel uses small patches of fiberglass in the fork and frame where metal parts attach. Aerospace structures do the same. See NASA's document TM-584C, CORROSION CONTROL AND TREATMENT MANUAL.
The Velvet Curtain said:That's because you live in a hard water area, you need to fit a filter.
