JtB
Prepare a way for the Lord
- North Hampshire
The RCD on my consumer unit seems to be randomly tripping.
By process of elimination I’ve identified a number of circuits and appliances which are not at fault but it’s proving quite difficult to home in on the actual problem due to the intermittent nature of the tripping.
Last time it took 12 days for the RCD to trip and it’s always the main RCD that trips and not the MCBs protecting the individual circuits. Last time the RCD tripped it took several attempts to reset it. On each attempt I switched off a different MCB until I was able to reset the RCD, but I don’t know if that identified the circuit causing the problem or if it was just coincidental because I was then able to switch back on that MCB again without the RCD tripping.
Any advice on next steps would be very much appreciated as I’m starting to draw a blank.
Many thanks.
Many thanks.
