GrumpyGregry
Here for rides.
I've tried searching but couldn't craft a good enough search string to find anything worth finding....
Back lights. Super duper bright ones. In this instance a seatstay mounted Smart 7 LED Polaris and a Smart 1/2 Watt Lunar, one atop the other, but that is not important.
Any methods/science/geometry for aliginging them for maximimum effect/visibility to car drivers? I'm thinking along the lines of
"measure 1m off the floor against a wall, mark a vertical line and horizontal line atop it like a T, with your bike lamp 5m from the said wall and perpendicular to it you want the body of the lamp light to hit that the intersection of the T."
I want to be visible aways off, especially in daylight, but I don't want to end up "under the radar" closer up.
Over to you.....
Edit: changed chainstay to seatstay. my bads.
Over to you.....
) pointing horizontally on the saddle bag. Seems to work (famous last words!). The best way to check the visual impact of your lights is to get someone to ride your bike and drive past them.
