summerdays
Cycling in the sun
- Bristol
I'm getting fed up of my waterproof trousers leaking! The current pair are ones Mr Summerdays bought but ordered the wrong size. He wore them for a bit before buying the correct size so I decided not to waste them. They are endura ones, don't know exactly but they say PTFE protection on them and suggest a breath ability of >28000g/m2 and waterproofness of 12000mm.
I like waterproof trousers with zips or openings at the bottom to make it easier to go over shoes. I don't want to be wrapped in a completely non breathable material, but I can put up with a bit of dampness from within as long as it keeps the majority out.
Obviously I have worn mans ones before but I would like a ladies version, though it needs to have long enough legs for 32 inch. Any recommendations or ones to avoid?
Though I'm hoping we will be due for some very shortly! I do need the full waterproofs as I've already had a significant number of the number of wet rides you are supposed to get each year.
so shouldn't be sweaty. Started at £100 so,would expect some degree of quality in the technical fabric
