Setup:-
I've an ICE Sprint modded slightly to my specs.
As I lost an arm to a Tiger attack, it's set up with all the hand controls (brakes/gear change) on the right hand side. This is why I ride a bent trike and not an upwrong bike.
I also find the hard shell at it's most reclined fits me better.
But the major mod was the gears. I've a Schlumpf HSD with twin chainring on the front and a Rohloff built into a 20" wheel on the back. This gives me an ultra wide gear range of 9.4"-178". Even with a full camping load, in first gear only hills steeper than 20% are hard work and it's very rare for me to spinout on descents.
I've a set of radiclesidebags on the seat-rack.
Plus I've a large Carry Freedom trailer with an aluminium box bolted straight to the frame.
This gives me around 100 liters volume for roughly 10 kg extra weight.
For power I've a Son hub dynamo to keep my sat nav charged and a 20 watt solar panel on the trailer to keep any cache batteries/ other devices charged.
I've always camped on my tours with the very odd hotel/bb if the weather got very bad.
Issues:-
Trying to follow Sustrans routes. Illogical routes with bad signing with unknown surfaces ranging from good tramac through rough macadam to a mud track in an open grass field with the odd impassable anti-cycling barrier add for "fun" .....
. I'm not a fan of them and will only try to follow one if I feel like it.
The odd uphill stretch on a narrow twisty road when it's busy due to speed difference around blind bends leading to dangerously bad overtakes. It's rare as it tends to be the case of "wrong place at the wrong time" but it can happen. Tends to happen around rush hour going into/out of a city/large town so I may adjust the time I setoff/finish to help mitigate it if it's possible.
Rear tyre wear in the wet on steep hills. I use a 50-406 Big Apple tyre on the back just for this reason. I've found there's more more rubber to wear away before you reach any vital on this tyre compared to lighter tyres so it lasts longer. Not vital on a short 1,000 mile JOGLE but could be on a longer +4,000 mile tour. Try finding somewhere that sells good 20" tyres outside a main city ......
Luck ..........
