roadiewill
- Wiltshire
is this a relatively easy thing to do? what tools would I need?
cheers
cheers
Unless it is one of those cheap, horrible, riveted-on ones in which case it won'tTHe granny ring will just unbolt off the crank spider thingy.
!roadiewill said:is this a relatively easy thing to do? what tools would I need?
cheers
Yorkshireman said:all you need is an allen key (though you would have to remove the r/h crank and the chainwheels first
andy_wrx said:Not the crank, you can simply remove the outer chainrings and then waggle the smaller one past the spider and over the crank.
I did this to replace my inner with a smaller ring
I guess you might also have to remove the pedal if you were using platform pedals with toeclips as it wouldn't fit over it.
Alternatively, if you did remove the crank you could then simply remove the inner ring without having to touch the outer rings.
If you have a triple but want to go double, I suppose you could remove the inner one and adjust the front mech stop-screws to only allow the shifter to select the remaining rings....but I really wouldn't bother.
). It's only one crank retaining bolt and the four allen bolts and took about 10 minutes (other cranksets will differ).didn't 'register' (until after I'd finished playing bike mechanics ... and posting) ...my bad.Alternatively, if you did remove the crank you could then simply remove the inner ring without having to touch the outer rings.
