rockyraccoon
Hi, I need to replace the axle on my vintage bike which has snapped recently... I'm looking for a straight and "ea$y" solution..
The horizontal dropouts have a space of 120mm and the alignment is correct (symmetry). No damage to the frame.
The current axle that has snapped has a length of 135mm. The cones were damaged so looking to get all replaced.. Hubs look fine also ball bearings.
The OLN is 126 mm.
The 6 speed freewheel is a
SunTour Pro Compe
The rear wheel is still in good condition and the bearings are OK.
So my question is if I was going to get a new axle with cones, spacers, etc and considering the dropouts spacing, should I get one with the same length 135mm? Would any other length be better? If yes, why?
The OLN is 126 mm. Keep it as it is or change it? Why?
Cheers
The OLN is 126 mm.
SunTour Pro Compe
Cheers
