MacB
- Farnborough, Hampshire
Okay this is all brand new and is priced for a quick sale, it will be going on e-bay tomorrow evening. Pictures are here:-
https://www.flickr.com/photos/37729119@N08/
Price is £1800 ONO(this is about what the wheelset and forks cost) collected from Farnborough in Hampshire, happy to ship as well but will need to be insured so probably £100ish
Frame - Angus Taylor custom steel 29er with fittings to allow for racks and guards. Rear dropouts are Paragon Rockers with the inserts for the Rohloff hub. Frame is beefed up enough to take up to a 120mm fork. Geometry is ST CtoT 485mm, TTE 625mm, HTA 72, STA 74 with 450mm custom steel forks, HT length 120mm, trail is 79 with current setup, reach is 440mm, seatpost 27.2 seatpost clamp 30mm, BB 73 English - PLEASE NOTE THE FRAME DOES TAKE A 27.2mm SEATPOST BUT IT IS A TIGHT FIT
Forks- custom steel 29er from Waltworks in the US - idea was that these would be the road/touring forks and swapped out for boingy ones for offroad. Forks have fittings for racks and guards
Headset - Hope 1 1/8 black - note some scuffing on top cap, my fault a bit clumsy in garage
BB - UN55 122.5mm to give 55mm Rohloff chainline in middle ring
Chainset - Shimano Alivio FCM410 black with rings removed and replaced with Thorn steel 38t reversible chainring in middle ring and Thorn bashguard in outer position
Seatpost/Saddle - generic 30mm bolt up clamp and 27.2mm black seatpost, saddle is WTB SST
Brakes - Avid BB7 Mountain 160mm front and rear with Avid speed dial 7 levers and Goodridge compressionless outers
Wheelset - Rohloff 36h black rear and Hope Pro 2 36h black front, laced to Velocity P35 rims so limited to a 700x35 tyre upwards. Velox rimtape, Schwalbe 29er tubes and Halo Twin Rail 29x2.2" tyres. Rohloff is all setup at 38x16 and shifter installed etc
Cockpit - On-One fleegle bars(very wide) with short 60mm FSA stem and Ergon Rohloff grips with bar ends
Extras - a couple of resin bottle cages, a Tortec expedition rear rack and clip on Beavertail mudguards. If you want to fit full mudguards then you either limit yourself to 700x50 slicks at the max or import Planet Bike Cascadia 29er Fenders from the US which will accommodate up to 700x60
Pedals are just cheapy flats which I wasn't planning on including.
