It won`t be costing me a penny, as it`s done by the local dental school, I just keep hearing nightmare stories..............Yep I had to have it done by a specialist a couple of months back...two hours with a course of antibiotics in between, my canals were a mess...and waiting to see if it needs doing on another bit
The most painful bit is the bill...you do not want to know what an endodontist charges![]()
Have it done privately, I now avoid NHS tooth butchers like the plague
Also need both teeth crowned, also an eye watering amount (together, you coould easily have a branded carbon bike with ultegra or titanium!)
Had sedation when I had a wisdom tooth out a few years ago, it was lovely!!From a fellow dental-phobic wimp () - I think you need to consider sedation!
I have a horrible stump of a tooth which I should have had pulled out months ago but I have not plucked up the courage to get it done yet. Even toothache didn't persuade me to make an appointment ...
Blimey - I didn't realise how expensive dentistry is!
How much would it cost to just pull a tooth out? Mine might be complicated by the fact that it doesn't protrude beyond the gum line so they might have to cut the gum to get a grip on what is left. I think it will just break into 2 or 3 pieces which will then have to be individually removed. Oh, and I am also worried about excessive bleeding because of being on warfarin, though I'm sure that dentists are used to dealing with that.
