Salt
Shorinjidude
It's your money - £11.90 for what a can of WD40 does or indeed any oil or grease ?
This stuff just lasts and lasts, how often to you need to top up the WD40? This is a light foam that once applied you have no need to worry for the rest of the winter. Also kills off the old rust as well. Anyhow, just my two cents - off for a £12 pizza now :biggrin:
henshaw11
Walton-On-Thames
Somewhat different - esp wrt wd40.
You can spray it on at the beginning of winter, it stays on, reapply it as/if necessary, then wash it off when the weather clears up/ following summer (two may not be coincident, of course !). If it's the stuff I'm thinking of, the particularly good thing about it in the case of motorcycles is that it's fine for engine casings, exhausts etc that get hot whereas grease/wax related stuff wouldn't stay on for long.The first year I rode my cbr over the winter I was horried with the state the unpainted/lacquered engine casings had reached when I came to remove the fairing lowers in the spring - I don't think ACF50 was available here 10 years ago...
