yashicamat
- Macclesfield, Cheshire
Seeing as my employer has finally decided to offer the cyclescheme, I thought I'd look into getting a 'proper' road bike, rather than bobbing about on either an old steel singlespeed or my touring bike.
My budget will stretch to the above mentioned bikes, with the Boardman being the best on paper (to my relatively inexperienced eyes . . .) and having an excellent review. The only problem is this apparently common issue of the spokes coming loose, plus the fact that I'd have to set up the bike myself as the chances are that the Halfords staff would make a mess of it.
The Scott is the LBS choice, so would come well set up and any issues would be easily rectified - the issue with this one is it is relatively heavy with an alloy frame and a slightly inferior groupset to the other two.
The Planet X seems to have this confusing '10% charge' when purchased with a cyclescheme voucher (which, as far as I can work out, is the only method of payment my employer will pursue). I presume this extra £100 over the £999 list price would come directly out of my pocket, otherwise it wouldn't be available on the cyclescheme at all. The groupset is quite appealing, though.
I was just wondering if anyone had any thoughts or comments about the above bikes? At the moment I am leaning towards the Boardman with a mind to buy a spoke key and tighten the spokes myself (I assume a half turn across the wheel shouldn't affect how true they are but will hopefully resolve loose spoke issues). The set up of the gears will be a learning curve I suspect (I am used to friction gear levers) but I'm sure I'll work it out given a bit of time.
Cheers.
Rob
Cheers.
Rob
