AlanW
- Not to sure?
I used my new Kickr Snap trainer for the first time last night, while the ride is very, very realistic the fluctuation in the wattage figures is rather alarming, so I'm something isn't right? My Tacx Vortex didn't do it, nether did my Kirt Kinetic Rock n Roll trainer.
On the flat maintaining the same speed and the same cadence yet the wattage is fluctuating 20 or 30 watts all the time?
I did have the wattage response time set to "instant" in Zwift, but even altering it to "3 second delay" its still all over the place?
Then just to add to my woes, when I came to a climb, I dam near came to a stand still as my speed dropped down to 2mph. In fact at one point I thought that the virtual me was going to get off and push! It also seemed to slow increase the resistance, so it only started to kick in after 5 degrees I think?
I did the spin down test first using the Wahoo app, then shut the app down and turned off the Bluetooth, then opened up Zwift and connected everything via Ant+. But my understanding is that only one app can control the trainer at a time, so what's the point in doing the spin down test with the Wahoo app, only to shut it down??
The Ant+ dongle is on a 1.5 metre USB extension cable, which sites it directly under the trainer. So I'm pretty certain that's not the problem.
As I understand it, which makes sense I guess, but you cannot have two applications controlling the trainer, ie Zwift and the Wahoo app.
If I have read the stuff on the net correct, to start the ball rolling you open up the Wahoo Utility app, turn on the Bluetooth and connect your phone via the app to the trainer. You then pair the trainer, the speed sensor and your heart rate monitor to the app. At this point it will advise you if you need to do a firmware update or not. In my case, it had the latest firm date.
From here, you carry out a spin down test as per the instructions on the app. Advanced spin down first when you first connect the trainer, then standard spin downs thereafter. Now according to Wahoo, the ideal spin down time is between 12 and 15 seconds. Adjust the tyre accordingly and retest if required. Once that's completed, shut down the Wahoo app and turn off the Bluetooth.
Now open up Zwift and pair everything via Ant+ and then off you go. How easy can it be......and while yes it loads the resistance up, its seems very extreme on occasions to the point that it brought me to a standstill last night!! Reading other peoples thoughts on the Zwift Q&A page, they mention ERG and SIM mode in the Wahoo app and how this can effect it. But I don't get that coz the Wahoo is shut down so how can it still interface with the trainer??
Which then make me question, if you do the spin down with the Wahoo, how can that effect what happens in Zwift as the two are not connected? I get the spin down test if you intend to utilize the Wahoo app to train with, but to do it and then shut it all down, doesn't seem to make sense. Perhaps I'm missing something??
