any body have info on setting up a lidl computer 2005 lost the manual :D
B barney magrew Guest 22 Oct 2009 #1 any body have info on setting up a lidl computer 2005 lost the manual
Chamfus Flange Well-Known Member Location Woking, Surrey 22 Oct 2009 #2 not sure if this is of any help safemanuals.com/reference-TRONIC/1 .
RSV_Ecosse Senior Member Location Bonnybridge, Scotland 22 Oct 2009 #4 barney, does your Bikemate computer look like this one? :- If so, it's the same one I use. I have the printed manual here, I can try scanning it and emailing to you if that helps?. Regards, Gaz.
RSV_Ecosse Senior Member Location Bonnybridge, Scotland 22 Oct 2009 #5 *EDIT* Actually, no need to scan it as I found it for download as a .PDF file after checking the support website listed on the back of the manual. If it is the same as the one above, the MCP 30084 version, here is the link to download the manual from :- http://www.mcp-ag.net/download_pdfs/Fahrradcomputer_30084/MCP 30084_Manual.pdf
fossyant Ride It Like You Stole It! Location South Manchester 22 Oct 2009 #6 Also check the 'sticky' on know how for the Aldi computer - none wireless one
OP OP B barney magrew Guest 23 Oct 2009 #7 thanks for the info i have managed to get it going thanks again
