Just thought I will share this and also wondered if anyone else encountered the same issue. Had to remove damaged link which was slightly pushed out when pinning and got caught in the cassette. Initally it was spinning fine and then it had those small jerks once in a while. This chain is narrow and the tolerance would therefore be much less.
So if you have newly installed chain and heading out on a long ride just be ready with the right pins or a 11 speed chain connector as the 10 speed would not do and you might have to remove damaged link.
