yenrod said:
What your better doing Colin is getting a longer variant THEN putting it up !
Agreed.
As well as making the steering that much more responsive, which if you intend to reduce the length by 30mm or so, that's a big reduction not to have an adverse effect?
Why not keep the stem the same length and add spacers underneath it, or flip it over MTB style?
IMHO reducing the stem length to get more upright is not the correct way to adjust your riding position. The length of the stem is determined by process of other measurements, seat position for and aft, top tube length and arm length etc.
I bought a frame a few years ago that had a top tube longer than I would usually ride. In truth I didn't realise until I had finished building it up with my usual length stem, 11cm.
So I did the same and reduced the stem down to a 90cm one, terrible consequences with regards to the steering and the way that it handled in general, it was just to twitchy.
I tried to get along with it, but it was no good, it had to go. Bought another frame with a smaller size top tube and reverted back to my 11cm stem...perfect!
