Arch
Married to Night Train
- Salford, UK
Right. I got the Galaxy powdercoated, and a new headset put in, and the old front cable hanger no longer fits under the top locknut onto the headset (it was the old sort with a notch to locate it in the headset, and is too narrow a diamter to fit over the current one). Clamp-on cable hangers designed for cyclo-cross bikes are meant to clamp on a 28mm stem, my stem is about 23 mm, so I'm thinking that would be way too much difference to shim. Never mind, I found a nifty Kona hanger that bolts to the forkcrown, and points upwards. Last night, thought I might try and cable the brakes up, but find that the straddle wire I bought to go with the cantis is too long, and the hanger point is too low. I can't seem to find the shimano straddle cables in any other size, although Sheldon suggests they are made, and indeed, my old ones (rather rusty) are shorter.
Looking this morning I've found the Clarks Universal brake straddle wire:
http://www.halfords.com/webapp/wcs/...alogId=10151&partNumber=678854&langId=-1#dtab
Will this do the trick? I guess I also need the little triangular hanger thingy as well to attach the main cable to (would Halfords also have them?).
As far as I can see, the options are a shorter straddle wire ( is there a source I haven't found by googling?), or using the old hanger and having it filed out to fit the new, wider headset (I have a mate who could do this, I think), or to have the clamp-on one and shim like crazy, which strikes me as a bit ugly, and possibly not safe (more to slip). Is there an obvious solution I'm missing? I'll go into a bike shop and ask if I think I know what I want, but I'd appreciate some advice from folk who won't make me feel small if I'm being stupid...
