xxmimixx
- a different place on earth...
I need two small stems, the smallest the better!
Please let me know if you have one
Thanks
Mimi
Thanks
Mimi
for what size bars?
I have an 110mm for an oversize bar. Any good?
I've seen them down to an 80mm - I currently use a 90mm.not sure, what is the smallest size on the market?
its the meaurement where the stem clamps onto the bars thats important,
http://www.bikeman.com/bicycle-repair-tech-info/bikeman-tech-info/1637-handlebar-diameters
The diameter of the central part of the bars - measure around the outside of it then divide by Pi - should be 31.8mm on an oversize bar.so what colour area do I need to measure??![]()
Yes - that'll make it a 26mm handlebar. My stem won't fit as it's for a 31.8mm (oversize) bar.the circumference is 80mm does it make sense?
25.4mm diameter. I have one but the reach might be too long - let me find a measure... not sure if it is 90mm or 100mmthe circumference is 80mm does it make sense?
That should do it. Do you really want it that short?thanks all Im glad it makes sense to you
blimey they are expensive !! This is the cheapest I can find, I hope is ok
http://www.ebay.co.uk/itm/New-ZOOM-3D-Alloy-Short-Stem-25-4-X-50mm-189g-/130672919165?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item1e6cb6827d
Yes is for my son first road bike. the 100mm is making him stretch too muchThat should do it. Do you really want it that short?
