summerdays
Cycling in the sun
- Bristol
Ok - so I admit I have sinned and not looked after it properly..
. so I've brought it inside and cleaned the rust off the chain - amazed how much had appeared since its last clean about a week or so ago. The links feel quite stiff so I have put on more lube than normal ... will that help?
Rather weirdly the wheels also feel if they aren't running smoothly (disk brakes) - more than normal. Is there anything on the wheel that needs looking at other than the brakes? or lubricating in this weather?
. so I've brought it inside and cleaned the rust off the chain - amazed how much had appeared since its last clean about a week or so ago. The links feel quite stiff so I have put on more lube than normal ... will that help?Rather weirdly the wheels also feel if they aren't running smoothly (disk brakes) - more than normal. Is there anything on the wheel that needs looking at other than the brakes? or lubricating in this weather?
