I'm not talking about the quality of them, but their existence, and whether we should just put up with the shouting so that someone else can benefit from their existence.
I agree that a lot of them seem to have been designed by the PG Tips monkeys.
As we can see from the poll, drivers shout at us to get off the road even if the paths aren't there. We shouldn't have to put up with abuse, but some people will always be idiots, and I really don't think it's that bad. Anyone cycling on the road has to do a large amount of grinning and bearing.
As I've said before, I don';t have an in-principle objection to off-carriageway cycle paths, but that doesn't mean the problems they can cause can be dismissed as simply the sort of thing we have to put up with anyway.
The 'get on the cycle-path' problem is inevitably very localised. If you don't happen to have one on your regular route you probably won't encounter the problem very often. On the other hand, if you have one on your daily commute, as I have, then it can become a big cause of conflict and irritation. I don't think it is fair for those who don't have that sort of problem to tell those of us who do that it really isn't that bad; for us it is! We don't actually have that much cycling infrastructure in this country, so it isn't surprising that a large proportion of cyclists will rarely encounter this situation, but clearly it will become more widespread if more of that sort of cycle path is created.
The problem is not simply a manifestation of the normal dislike of cyclissts which we'd get anyway. I only experience hassle on the section of my commute that has an adjacent cycle path (and another bit that people think is a cycle path, but isn't...). As I've pointed out before, the abuse is only the tip of an iceburg, with far more motorists irritated than are expressing it vocally. Indeed, there are an awful lot of people who are genuiunely bewildered that cyclists dont' use the cycle path. For them, cycling is a dangerous (and slow) mode and the only reason they can think of for cyclists not using the path is that they must be deliberately annoying drivers. Thus the crappy cycle path has added conflict to the relationship between cyclists and motorists that wasn't there before.
I also disagree with the assumption that less experienced cyclists are fine with the extra side road crossings etc simply because they are going slower. Every additional junction is an added risk, and pavement paths usually connect with the road at places where the turning manouvres are more complicated, with more conflict, than you get if you stay on the road. It is wrong to give people a false sense of security.
Again, I'm not arguing that there should never be off-carriageway paths adjecent to the highway (indeed there are a few, very few, that I do actually use myself!) but it is imperative that those who create them take full account of the needs of existing cyclists and do not unnecessarily introduce conflict. The guidance as set out in the National Cycling Strategy etc, with the Hierarchy of Measures etc is there for a very good reason and, more than 10 years on, really ought to be being applied by now.
