accountantpete
OAP
As new - original owner took a few pics but no real usage at all.
Comes with 2 new batteries, 4GB Kingston Micro SD card, USB connector and CD.
Good bit - easy camera to use (point and pray!) and surprisingly good quality. Marketed as waterproof to 3M for underwater use as well.
Reviews here http://www.amazon.com/Polaroid-IF045-BLUE-KM-Waterproof-Discontinued-Manufacturer/dp/B008RFA1BS
Bad points - the USB connection goes through the battery compartment which means that the batteries fall out. Also the USB plug is a bit tight -presumably it will be ok with a bit of usage.
£30 posted
And here's a quick snap of Her Highness taken by the iF045 in bright sunlight.
£30 posted
