For Sale
Bought last year to use on an unsupported tour of France. Ended up doing it supported so this has never been used, only trial fitted my bike. Includes all nuts/bolts/fittings and instructions. Was an ideal solution as it is a trunk bag that can turn into panniers. With Topeak's QuickTrack™ system it takes the faff out of panniers.
Looking for £50 for both rack and bag, including postage. Viewing/collection welcome too.
Here is a video clip which explains how it all works.
MTX TrunkBag DXP
and the pics...
Explorer Tubular Rack A tough tubular aluminum rear rack perfect for classic loaded touring, commuting or just running errands. QuickTrack™ compatible for use with any MTX TrunkBag and rear basket.
Attachments Braze-On Type Material 6061 T-6
Hollow Aluminum Bag Compatibility MTX QuickTrack™ System Max. Weight Capacity 25 kgs / 55 lbs Added Features Solid Fender Top
Fits All Frame
RedLite Mount
Tail Light Mount Size (L x W x H) 34 x 14.2 x 41.5 cm
13.4” x 5.6” x 16.3” Weight 625 g / 1.38 lbs Art.no. TA2026-B
MTX TrunkBag DXP This is our largest MTX trunkbag featuring a new process that marries rigid molded panels with flexible 600 denier fabric to make these our stiffest, most weather resistant MTX bags yet. The divided main compartment features a two-stage expanding top plus side panels that zip open into full panniers for even more capacity. Compatible with all MTX QuickTrack™ racks with attached side frames.
Compartments 1 Divided Main with Multi-stage Expandable Top, Two Side with Expandable Panniers Capacity 22.6 L / 1380 ci Max. Load Limited to Rack Maximum Load Rating Insulation Molded EVA foam Material 600 Denier Polyester Bag Attachment MTX QuickTrack™ with Attached Side Panels
Added Features Water Bottle Holder
Shoulder Strap
Carrying Handle
3M Reflective Strip
RedLite™ Clip
Elastic Top Bungees
Optional Rain Cover Size (L x W x H) 36 x 25 x 21.5~29 cm
14.1” x 9.8” x 8.5”~11.4”
Weight 1160 g / 2.53 lbs
MTX TrunkBag DXP
and the pics...
Fits All Frame
RedLite Mount
Shoulder Strap
Carrying Handle
3M Reflective Strip
RedLite™ Clip
Elastic Top Bungees
