Solid axle for a rear wheel?
swee'pea99
My new fixie's coming together nicely, but the wheel I have in mind has a QR, which I'd like to replace with a solid axle. Anyone have one hanging around? The rear droputs are 130mm spaced, so I guess I'd need, what, 160? Something like that. Thanks.
ASC1951
Yorkshire
No, I'm already using mine on my fixie.:smile:
Any bike shop will have one, because that's what they use on all lower end bikes, don't they? You need to make sure it is exactly the right length otherwise the the bearing cone will be in the wrong place.
Sheldon reckons that you can use QR skewers without any problem. http://sheldonbrown.com/fixed.html I did that with my first conversion and it was fine.
swee'pea99
swee'pea99
Thanks for that (and apologies for not saying so earlier). Maybe I'll try QR - after all, if St. Sheldon says it's ok...
