Old timer
- Norfolk, UK
Of late I`ve noticed a couple of times that my internet pc has closed down all on it`s own. Thinking it might have been when MS downloaded an update and it didn`t boot properly. Then two days ago it closed down while I was using it on the net, I rebooted and after 2 mins it closed down and so it went on. I had fitted a new power supply two months ago so thought that it might be faulty so I stuck a spare in and still the same. Anyway, after speaking to a good friend (Mr PC I call him) he told me to check to see if the cpu heat sink was firmly in place. Sure enough, one of the fixing lugs on the MB bracket had snapped and there was movement where the heat sink wasn`t in proper contact with the cpu and it was shutting down as it over heated. I fixed the broken bracket by using a small cable tie to hold that corner down till I sourced a new mount and it is fine now.
Just thought I`d share as I`m told by my friend that it is a lot more common than you would think and many people trash the pc for a new one thinking it`s the motherboard and not economical to replace.
Dave
Dave
I buy when I need it now
I always think of my PC as been the same one I first built, just everything upgraded several times
(A bit like triggers broom - he had the same one for years, it just had 4 new heads and 7 new handles)
