SON28 - Change from quick relase to through axle?
PaulSecteur
No longer a Specialized fanboy
Hi,
A while back I had some wheels built by DCR - very impressed with them.
Im thinking of getting another front made up but using a dyno hub. I like what I hear about the Son28 for reliability.
The bike that wheel will be on for the next year or two is a standard quick release (Specialized AWOL) but looking to the future I might get a carbon Diverge that has a 12mm through axle.
Can the axles on the SON28 be changed to suit different configurations?
Cheers, Paul.
andrew_s
Gloucester
Both SON and SP do their thru-axle dynamo hubs in 15 mm - I don't think there is a 12 mm thru-axle dynamo hub.
You can get adapters to run a 15 mm thru axle wheel in a bike with QR dropouts
http://www.chainreactioncycles.com/nukeproof-conversion-kit-15mm-to-qr/rp-prod80192
There is also an adapter to run a 15 mm wheel in a 12 mm fork
http://www.ebay.co.uk/itm/MTB-Tools...hru-Axle-Adapter-for-100mm-Fork-/262122494769
I doubt you can convert a QR dynamo hub the other way
