I got wheels covered just have to wait for c2w to open back up and checking out all viable optionsWhat do you need to know...it's a entry level TT machine, reasonable spec, but with room to upgrade if required. Biggest upgrade would obviously be wheels.....
If it fits the bill and budget then N+1 away lad....
I built a TT based upon Planet X frame...worth a look if you fancy a self build:
Two bottles fitted as I was doing a long distance event. It now has a single aero bottle fitted.....
The question is, unless you have tested the frame/bike to be quicker with the current bottle setup, why are you carrying it on the bike at all?
Because the aero bottle has a minimal cage/fastener thingy meaning I can have the bottle for long TT's or not for short without it looking ugly. Like you say I'm not sure of any benefit, but hey does there really need to be a reason? The only reason I fitted two cages for this photo was I was doing 100 miles on it around the fens and needed the liquid.
What I mean is, for short TTs unless the bike is faster with the bottle, you should take it off completely as it could be increasing drag.
You could do some field testing if you have a power meter?
Attention to detail![]()
