Speed Discrepancies
Vantage
Carbon fibre... LMAO!!!
I'm using a Tacx Blue Matic (supported) and speed sensor only. My weight and height have been saved.
The only odd bit out is that I'm running a 35mm tyre and zwifts biggest is a 32mm.
Spinning my little legs out using a 46t front and 11t rear Zwift says I'm only doing about 20mph which is horse apples.
Can that be fixed?
screenman
Can that be fixed?
I would say you are only doing 0 mph.
Sharky
Kent
44x11 - that's a massive gear (105"). What cadence are you getting to?
65rpm would be about 20mph
ColinJ
Puzzle game procrastinator!
Does the speed sensor depend on a magnet attached to a spoke on the rear wheel? If so, I'd make sure that the gap between the magnet and the sensor is as small as possible and that they are perfectly aligned with each other. I reckon that some of the passes might not be registering?
Specialeyes
Essex
On a non-smart trainer Zwift is only interested in approximating your wattage output through Z-Power. Is the trainer resistance set correctly? (I'm assuming Zwift supports the trainer itself). You could be spinning out on low resistance and only producing enough watts to shift your avatar at 20mph.
More info here:
https://support.zwift.com/en_us/zpower-setup-r1XjaXbxr
Tigerbiten
I'd check your tyre size in the setting on Zwift.
46/11 on a 20" wheel at 90 rpm is around 20 mph.
Luck .......... ^_^
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
Zwift speed isn’t based on wheel speed. It’ll do a calculation that takes into account trainer profile and rolling resistance of turbo. This is what calibration is all about.
CXRAndy
Lincs
Zwift uses power, weight to calculate speed. Ideally power meter should be used for Zwift
