Sram FireX crank
llamafarmer
Hi,
The left crank on my Sram FireX 9x3 gpx crank set came loose, and now won't stay tight anymore.
I can see the crank arm splines are damaged, but the mating faces on the shaft to the drive side look OK.
My question is, is there an alternative left gpx crank arm which will fit as FireX doesn't appear to be available anymore.
Thanks
