If you know there is a bus stop ahead. But if you don't? I have to admit that I generally avoid filtering up the left of large vehicles, but in this case both myself and the cyclist in front were in a cycle lane. Anyway lesson learnt for me. But I still think the bus driver was at fault. Particularly as the leading cyclist was in front of the bus when they pulled away from the lights.
Stupid mistake from you both. Really dangerous unless you really know the road layout and you have the power to out run a bus, neither of you did.
Let me correct you on one point. There isn't an ASL.I think the main points are: Bus was not indicating. Cycle lane leads into an ASL and the light was at red. Lead cyclist had reached ASL area as lights start to flash and Bus driver must have seen cyclist. Bus jumped flashing amber.
So we are not meant to use ASL or designated cycle lanes in case muppets ignore cyclists. I would certainly not filter up the right especially when there is a cycle lane to the left for fear of being right hooked when the lights change if the lead vehicle sees no traffic approaching I doubt they would check their mirror.
OK having said that I agree the odds are that drivers are muppets and that you where putting yourselves at risk, but not through technical fault on your part. I would most certainly report the driver, afaiac he was just a bullying pillock making a dangerous point because you had the tenacity to use the cycle lane/ ASL.
In fact I am amazed he left space in the ASL most of the idiot buses round here make a point of stopping into the crossing ie stopping over the ASL just to stop cycles getting in front regardless of where they filter from,cycle lane or not.
Edit: lead cyclist doesn't do either of you any favours setting off so slowly though, as mentioned as the second cyclist you should have backed off regardless, I would still report his driving though.
If there was an ASL (see my post above), then the driver would be completely at fault.Out of interest does anyone think this situation would have been any different had the cyclist been sat to the left in the ASL before the Bus arrived at the red light? Does anyone think the Bus would have stayed behind the cyclist when the lights changed?
I couldn't agree more with what others have said about not filtering on the left of big vehicles at junctions ... but in this situation, I hate to say it of myself, but I would VERY easily have made the same misjudgement. Brain working in "cycle lane mode" rather than "junction mode". Hmm.Pelican or Toucan Crossings should be treated similarly to junctions. I bet if that was a HGV you wouldn't be in 'cycle lane mode'Just an observation - there's quite a lot of poor observation in this thread?
Fwiw, not knowing the road at all, I find it bewildering that the cycle lane passes inside the zig-zags for the light-controlled crossing; that's plain odd. And then the cycle lane quite clearly carries on past the lights.
Since the bus isn't indicating that he's going to cross the lane to the bus stop, and indeed barges across, yes I do think it's worth reporting.
I ......... how to put it ..... wouldn't phrase some of the comments above quite so strongly?I couldn't agree more with what others have said about not filtering on the left of big vehicles at junctions ... but in this situation, I hate to say it of myself, but I would VERY easily have made the same misjudgement. Brain working in "cycle lane mode" rather than "junction mode". Hmm.
I bet if that was a HGV you wouldn't be in 'cycle lane mode'![]()
