KneesUp
What bike would you recommend that meets the above requirement
I'd like steel for the look as much as anything, but also for the idea that should anything happen to tube it can be replaced. Not that I ever will. Aluminium doesn't appeal because it fatigues, and because I grew up with thin tubes. Carbon is for barbeques and, like titanium, is far to expensive for me :-)
I'd like a bike that can be used for pretty much anything. Most days for commuting (hills, badly made roads) but I'd also like to do a bit of touring as I get fitter, so I want lightness and comfort. I'd like a bike tough enough for a bit of mild off-road - not full on mountain bike stuff, but perhaps rougher than a canal path - like green laning on a bike I suppose. Ideally I don't want to spendanything much more than £1,000.
So far I've come up with a short list that consists of two bikes:
Genesis Croix de Fer
Planet- X Kaffenback
The Planet-X is considerably cheaper, which is good as I am from Yorkshire (which also means I can go and have a look at the Planet-X fairly easily). However, the Genesis looks nicer and can take fatter tyres, which might help with the mild off-road thing. I think the Planet-X can only take up to 32m with mudguards, whereas the Genesis will take 35mm. Is that much of a difference in real life?
Thanks in advance.
Thanks in advance.
